BmsSuite - How to setup cloud data storage for the BMS via ThingSpeak.com
Useful for easily enable remote viewing of the BMS data over the internet. Many of the custom selectable charting fields are available to be transmitted to the cloud.
NB: ongoing updates will require a connected PC with internet access.
The software automatically reduces the update frequency when the values are stable and also reduces the time interval if changes occur. Optimising updates to give live streaming whilst reducing bandwidth when the system is idle. Only the system tray with relevant host application need to be kept running.
Step 1 - Register a account to the ThingSpeak.com
Step 2 - Create a account that you will push your data to
Step 3 - Create a new channel
Step 4 - Configure the channel
NB: Other field labels have be choose, these are typical options we have defaulted
Step 5 - Configure the visual charting options
NB: this only highlights the basic options, for more help read the documentation available from ThingSpeak.
Step 6 - Here is a outline of the example we have adopted as the demo for both the private and public view of the channel.
Step 7 - copy the write key to configure within BmsSuite
Step 8 - Within BmsSuite navigate to Logging > Cloud storage
Step 9 - Configure the WriteKey with matching configuration on Options tab
Step 10 - Configure the matching fields using the Wand selection
NB: align to settings within ThingSpeak, alternatively press the cog in the top right and press the default link
Step 11 - Press Start to store the configuration and run the processing agent
Step 12 - Monitor both ThingSpeak.com and the BmsSuite screen.
Check out the live demo at https://thingspeak.com/channels/173086#publicview
