How to connect the CellMon modules to the WatchMon4
CAUTION: Whilst initially setting up the cell monitors, make sure to only have the USB plugged in and then attempt to connect the CellMon wires. We recommend that you disconnect the WatchMon power supply (2 pin connector) and all other cabling until you have successfully connected the CellMon network. Ensure that the software network testing utility has confirmed that the communication link is working properly.
Multiple Cell Monitors or "multi string" configuration:
Do you require longer cables?
CellMon cables can be extended up to 4 metres, and the cable needs to be a twisted pair.
Next Steps:
Running the Wizard setup to define your system
Verifying the Cell monitors for faults using Network Tester
Synchronising the Cell monitors using Device Sync
Testing Cell monitors balancing resistors with Bypass Tester
Troubleshooting:
CellMon documentation:
How to connect / wire the LeafMon cell monitor
Hod to connect / wire the BlockMon cell monitor
BlockMon / LongMon technical data-sheet (PDF)
Connecting LongMon - battery pack chain (PDF)
How-to-connect-the-cellmon-modules-to-the-watchmon (older version of this page)
